Air Conditioning belt - NCRS Discussion Boards
  • Bob Moss
    I have a 1974 C3 454 vette. I bought it used. So I didn't see the engine set up from the factory. Apparently the previous owner had removed the AIR pump from this engine. Every parts store that I have visited has told me that this engine should have an AIR pump. My question is what size air conditioning belt do I need for this engine without an AIR pump? I know there is one because the car had a functioning belt when I bought it.
  • mike mccagh
    Re: Air Conditioning belt
    i've got a 74 454 4 speed C-60 and they definitly came with AIR (smog ) pumps. Any NAPA store worth its salt should be able to measure and match a belt from their stock for your car, whether or not you use a smog pump. good luck, mike
    • Bob Moss
      Thanks Mike:
      I'll find a NAPA store.
      Bob
      • Harmon C.
        • August 31, 1994
        • 3228
        Bob
        If you have an automatic transmission your 74 may have never had an air pump. Check your emissions label and se if it reads AIR.
        Lyle
        Lyle
        • Bob Moss
          Lyle:
          Thanks for getting back to me. You bring up an interesting thought.I bought this car out a divorce settlement in 1976. The folks involved couldn't reach a settlement. So their lawyers got together and sold all of their assets; including a home under construction that had a roof but no walls. Just bare 2 X 4's The guy that had it was a CPA. I doubt if he would have removed the AIR pump himself. I'll check the emissions label tonight.
          • Raymond W.
            • September 30, 2003
            • 248
            If you're interested in original style belts for your '74 (not sure about the correct markings and GM numbers), I had the best luck for locating the right AC, Alt., and Water Pump to Crank belts at Doc Rebuild.
            • Bob Moss
              Ray:
              Thanks for the feed back. I'll try there.
              Bob
