C1 Water Pump - NCRS Discussion Boards
C1 Water Pump
  • Rod Wagner
    C1 Water Pump
    Is there a replacement water pump for a C1 small block that does not have the pipe plug in the top?
    Thanks in advance.
    Rod
  • Bob Simard
    C1 Water Pump
    Earlier water pumps, circa 1960, are available from Bill Mock in Oklahoma City. These are rebuilt and do not have the pipe plug in the top.
      Re: C1 Water Pump
      Rod-----
      Rebuilt waterpumps without upper bypass fitting/boss are widely available. If you are just after configuration and not exact "numbers" you will find these quite easily.
      There is no NEW waterpump available that I am aware of that lacks the fitting/boss.
      • Gene B.
        • May 31, 1990
        • 144
        Re: C1 Water Pump
        I believe Goat Hill makes a new reproduction water pump without the plug.
