I recently sent out the gauges and distributor for a rebuild on my wife's '54. The only gauges not sent were the speedo, ammeter, and oil pressure, which had always worked. Got everything back, had fun getting the distributor in right, finally got it. Great.
Fire it up to set the timing. Ready to go for a ride.
Notice zero oil pressure. No unusual sounds, though. Disconnect line from back of gauge and fire engine. No oil comes out. Either there really is no pressure, or the line is clogged. Suck on the end of the line. Can get some air, but no oil. Since there are no bad noises, decide to go for a short spin.
On the way back, a squeaky sound starts, like a rocker arm not getting oil. Limp home slowly. Sound never gets too bad, but now I believe the gauge. After shutting down, some smoking is seen through the vents in the valve cover.
OK, so now I believe there is no oil pressure, but don't have a clue as to why. Are the oil pump and distributor both driven from the cam? There was no warning in the service manual regarding the possibility of disengaging the oil pump when installing the distributor.
Any suggestions on what to check next?
- Wayne
- Wayne
