Stripped Threads - NCRS Discussion Boards
Stripped Threads
  • Joe C.
    • August 31, 1999
    • 4598
    Stripped Threads
    All:
    I have a headlight bucket for 1965 which is mounted and finished, but with stripped machine threads on the lower(with buckets in the open position) tabs for the cover screws. These are the 2 black phosphate, flat Phillips head screws.
    The permanent fix would be to weld the holes shut with new aluminum, finish, drill/tap new holes. I am trying to come up with an easier way, AND continue to use the correct screws. Does anybody have any ideas. The main concern is to be able to remove the screws after the repair.
    Joe
  • Stephen B.
    • December 1, 1984
    • 98
    Re: Stripped Threads
    you could use threadcerts or heicoils I think the threadcerts do a better repair I think they are made by the same company Steve
    • Mike G.
      • January 1, 1991
      • 418
      No problem. First enlarge the hole by 50%. Then fill it with JB Weld leaving a nice blob on the back side for support. Use masking tape to control it until cured. Then just drill & tap.
        Slide a U-nut over the end of the tab.
        • Barry Chappell
          This would be the same type of insert that Steve mentioned.
          I have used these and they work great.
          threaded inserts threaded, stripped threads, threaded inserts, blown out sparkplugs, stripped threads, stripped out theads, inserts threaded inserts, ford sparkplug repair, threaded insert thread repair spark plug ford blown, blew out ford sparkplug, stripped theads, threads stripped out, threaded inserts for stripped threads, repairing stripped threads, thread repair kits and inserts, repairing sparkplugs threads, sparkplugs threads have stripped out, screw thread inserts, striped out threads, threaded inserts, automobile threads blown out, motorcycle threads stripped out threads, not helicoil use time-sert thread repair, screw thread insert, inserts for screw threads, screw thead inserts have stripped out
          Barry
          • Gerard F.
            • June 30, 2004
            • 3803
            I think I used a J-nut or one of those flat sheetmetal nuts on the tabs of my 67 light bucket. I buttered it up with some JB weld first then installed the bezel and screw tight before it took a set, so that it would stay in position. But I don't remember black phosphate screws, I thought mine were chrome or SS. Maybe a 65 is different.
            Jerry Fuccillo
            #42179
            Jerry Fuccillo
            • Joe C.
              • August 31, 1999
              • 4598
              Jerry:
              It is possible that '65 might be different from '67, but I don't believe probable. My 1965 TIM&JG calls for black machine thread Phillips for the bottom 2 screws, and chrome or cad flathead Phillips sheetmetal screws for the sides.
              Joe
              • Joe C.
                • August 31, 1999
                • 4598
                ALL - Thanks for the Suggestions
                My first thought was the U-nut idea, but I did not think that the screws were long enough.
                I found 1 that was made-to-order, and it did the trick.
                The other ideas were good too, but this was the fastest and easiest.
                Joe
