Attached is a picture of my original 67 base engine distributor:
About 14 years ago, I was having trouble with the tach drive gear, and I bought a repair kit with a new advanced crossgear. The kit required that a hole be drilled and tapped on the opposite side of the crossgear for a setscrew.
I got the kit, pulled the distributor and was preparing to install the kit when I noticed that the main shaft gear was also screwed up. I just wasn’t going to deal with this, so I put the distributor back on without the tach drive gear, and went and ordered a new rebuilt replacement distributor with the tach drive. They were a lot cheaper then.
When the new distributor came, I put this distributor in a box with the thought that some day, I’d restore it. Well, as you might have guessed, that day has come, and I’m sure glad I didn’t drill that hole. For the record, here’s the numbers on it:
The band says 11111194 Delco Remy 7 F 12 (fits my June 29, 67 car)
Casting on the opposite side of the housing in the picture is 170
Vacuum Advance on the top mounting plate has MS (above) with 355 below with 15 on the far right.
In cleaning it up, I noticed this green paint spot alongside the vacuum advance which shows up clearly in the picture. The rest of the housing looks like it was either painted black or was bare and has some black baked-on grease deposits.
So in starting this project, I’d like to ask the following questions:
1. What was the original finish of the distributor. Is the green paint spot remnants of the original finish or some factory marking?
2. If one changes the main shaft, should one also change the upper and lower bushings?
3. Are there any vendors out there who can supply an original distributor cap with the “Patent Pending” on it?
Thanks in advance.
Jerry Fuccillo
#42179
Thanks in advance.
Jerry Fuccillo
#42179
