Does anyone know a publication that will outline the assembly instructions for a dual master cylinder "Kelsey Hayes" double master cylinder "cast no.E48327 R1" Gm part no.3828760. They were equipped on Z06's and J56's. I was not the person that disassembled this cylinder and have questions surrounding its re-assembly. I would be thrilled with reference material or if such material could be faxed to me at my home that would work for me also. Thanks in advance. Larry
C-2 master cylinder assembly instructions
Re: C-2 master cylinder assembly instructions
Larry, I am familiar with the Z-06 master cyl, but the srevice reference I have for it refers to it as a "Moraine dual piston" master cyl. Please email me if you are referring th ehe unit with a screw on cap and dual outlets with the lines mating into a threaded plug. I can scan the sheet and email it to you. I don't have a fax at home.- Top
Thanks Bill,
You are correct in describing my master cylinded. Assembly instructions would be greatly appreciated. I've got some good used rubber parts coming from another Z06 owner. The rebuuid kits are hard to find. I'm hoping that whats one its way will do the job well. The cyl. is in good shape but the fellow that took it apart could have been a little more gentle. So all I need now is a little direction.
Larry- Top
