Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Chroming -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
There are lots of good platers across the country, where are you located?
Try searching the archives, this topic has been discussed lots of times. You'll find names like Areba, Paul's and Frankfort Plating to name just a few.
I would try to find one close by to save on shipping and in case you have to return something to be redone. Just my 2 cents.
Terry #11486
I was in San Diego about 3 weeks ago where I happened upon a Corvette Show given by the North County Corvette Club. They had some fine looking C-1 & C-2s and I asked them where they get their chrome plated. All had their chrome done at Lemon Grove Plating in National City, Ca. The only complaint was it took 15 weeks to get done.
Eric, I comment from years of experience with Frankford. They over promise and under deliver. I've waited as long as a year to get parts back. Not recommended.
