I need to replace my front right side brake caliper and called Vette Brakes in Tampa about buying a new unit. Before I do this I was told I need to know if my existing caliper has lip seals or O rings. How do I determine this? Thanks
C2 Brake Caliper Question
Re: C2 Brake Caliper Question
John-----
If the caliper has been on the car for more than 5 or 6 years, the chances are VERY great that it will have the traditional lip seals. Although the 0-ring style calipers have been around longer than that, they were not in widespread use prior to that time.
Plus, another clue: usually, if the calipers are leaking, it's a sign that the lip seals have worn out. The o-ring type calipers usually do not leak.In Appreciation of John Hinckley- Top
