I realize this is an extremely basic question:
I want to check the ground(s) on my '70 LT1.
How many gounding locations / straps are there?
Where are they located? At the starter? Exhaust?
A prominent guage & clock repair vendor suggested I check the ground connections for a good, clean ground, as a possible remedy for poor (too low) water temp guage reading.
I replaced the temp sending unit with correct pin-head style, and used one (1), and only one (1) time 'round of teflon tape seal.
I know, i know, it could be the tape! But, didn't the tape get cut by the grooves biting into the block upon install?
Before I re-do the sending unit WITHOUT the tape, I'd like to check the ground by making sure it's as good as possible?
The car starts. Everything else works.
Thanks!
Thanks!
