62- side glass rubber in Track - NCRS Discussion Boards
  • John O.
    • May 31, 1998
    • 480
    Hello all
    I need some help. After many years of my car sitting in pieces, I finally got to putting the side glass and frame together. I just purchased new side glass, track and rubber.My question is which way does the rubber go. It has a narrow channel for the glass to sit in then that goes in the track and a wide channel. I'm guessing that to be some kind of gutter. On what side does the wide channel go? On the side closest to the outer of the door or the inner side.
    Thanks for your help...If anybody has a diagram that would be great cause I can't find one..............John
  • Larry P.
    • June 30, 1999
    • 481
    Re: 62- side glass rubber in Track
    The gutter goes out and you will notice a notch on one end. It needs to be forward for clearance for the guide. When the glass is out remember the front is the side that slants foreward.
    I don't really want to talk about how I know these things. A 20" clamp with rubber jaws makes it easy to install, even if you need to do it 6 or 7 times!
    LP
    • John O.
      • May 31, 1998
      • 480
      Thanks Larry
      The tracks and rubber are new so it goes together easy.I think I may of put them on backwards. I'll check it tomorrow.
      Thanks....John
