Vacuum Advance Info For 65-67 BB - NCRS Discussion Boards
  • Michael H.
    • January 29, 2008
    • 7477
    Time to try to sort out all of the different vacuum advance units for all 65-67 big blocks. Need the three digit number stamped on your adv unit if you feel it's the original to the car/engine.
    There are questions on the 65 396, 66 390 and 425 HP and and all 67's. Please post the distributor part number and date if possible. Thanks.
  • Bill W.
    • March 1, 1980
    • 2000
    Re: Vacuum Advance Info For 65-67 BB
    65.396 #16120 has dist. #1111093 date5-C-8.. vac adv # 355..I will see 17346 this week end. I can check . It is also orig.Bill
      • 15610
      What are the vacuum can specs in the AMA specs?
      • Michael H.
        • January 29, 2008
        • 7477
        I Give Up...
        Looks like only one person has a 65-67 big block with the original vacuum advance unit?
        • Stephen L.
          • May 31, 1984
          • 3148
          Re: I Give Up...
          These are my numbers 67 L36 April 67 car.
          Distributor plate #2769047
          Vacuum Advance #MS 360 12
          Distributor date 6H15
          Distributor #1111247
            • 15610
            Re: I Give Up...
            Thanks. The 360 can meets the specs that are published for '67 L36/68.
