Unknown part in my 1968 - NCRS Discussion Boards
  • Geoff C.
    • May 31, 1979
    • 1613
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Dr R: My guess; head up only condom... *NM*
    • Terry F.
      • September 30, 1992
      • 2061
      Re: Unknown part in my 1968
      It looks like one of the fiber optic boots from either the front right or left turn signal. There should be an amber lens in it and the fiber optic cable plugs into it. I might be wrong but that is what I think it is. Terry
      • Geoff C.
        • May 31, 1979
        • 1613
        Terry,
        Under the forward console or on the park lamp itself?
        Geoffrey Coenen
        • Geoff C.
          • May 31, 1979
          • 1613
          Re: Dr R: My guess; head up only condom...
          Yikes Dennis
          It's only a 1/4 inch long. I'd be embarassed if it was in my wallet, even when I was a young k--- hound.
          Geoffrey Coenen
          • Terry F.
            • 2061
            Plugs into the back of the front right or left signal light that is attached to the grill is what I am thinking. Terry
            • Terry F.
              • 2061
              Does it have a hole at the tappered end?
              I might be totally wrong though. I know 68 real well. I don't recognize it from anything else. Was it a plug for vaccum tubing?
              • Geoff C.
                • May 31, 1979
                • 1613
                Terry,
                No hole and definately not a plug for vacuum. Too soft. Kinda looks like a very soft rubber tip for a luggage rack - slightly smaller than that hard plastic one on a rack. I stoopified.
                Geoffrey Coenen
                • Klaus Friedrich #33362
                  Hi Geoffrey
                  One question: Do you have any trouble with your neighbors or your family?
                  Best way to keep a Corvette driver busy (and of course out of the house) is to place some oil drops or strange parts under his car ...
                  Just kidding ;-))
                  Klaus Friedrich
                  #33362
                  • Terry F.
                    • 2061
                    Weird. I know my 68 very well. The only thing I don't know is an air car. Hmmmmm, sort of has me going. Well, it will give me something to think about when I am at work today.
                    Could it be used to protect the threads of a screw? There were some of those on 68's. If your car is a convert? Could it be some sort of bumper for that/rear deck lid? Hmmmmm...
                    Take care, Terry
                    • Dave F.
                      • December 1, 2003
                      • 508
                      Geoffrey,
                      If you look at the assembly manual UPC 12, B4.5 you will see attached to the back of the tach a valve part of tach asm that has 3 vacuum ports, which 2 have tubing attached to....my bet is your mystery part is the cap for the third, unused port.
                      • Dave F.
                        • December 1, 2003
                        • 508
                        additionally...
                        That valve appears to be part of the wiper door assembly. Does your wiper door function properly?
                        • Gene M.
                          • April 1, 1985
                          • 4232
                          your car must be early it is a rubber tip for a hard top or soft top forward latches.
                          • Wayne K.
                            • December 1, 1999
                            • 1030
                            Not a problem Dr.R, one size fits all. *NM*
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              i smell a repo comming. *NM*
