1965: vent door - NCRS Discussion Boards
1965: vent door
  • Twan B.
    • June 30, 2005
    • 207
    1965: vent door
    Hi
    My LH vent door is working correct (i've got to pull the knob to open it), but the other vent door (RH) works the opposed way. It looks like it is manufactured that way on the plant in Sept. '64. I can't see any damage of the body! Does anybody know?
    Vin # 194675S1004084
  • Geoff C.
    • May 31, 1979
    • 1613
    If you have to push to open the RH vent
    I think you may have the door mounted upside down. Flip it 180 degrees. The LH & RH doors are identical, but flip 180 degrees when mounted on the opposite side. Remember you had to push up to remove one side, and pull down to remove the other. Don't loose the (ancient ball point pen type) spring.
    Geoffrey Coenen
    • Twan B.
      • June 30, 2005
      • 207
      Re: If you have to push to open the RH vent
      I alreaddy thought this, but the rh vent is different form the lh vent.
      More suggestions?
      • Harry Sadlock
        Can you post a picture?
        • Twan B.
          • June 30, 2005
          • 207
          have no digital camera.
          Will try to post a picture this week. Good tip.
            Twan -
            The vent GRILLES (the black plastic louvered part) are right and left-hand parts, but the vent DOOR (the valve with the seal around it that moves) is the same part left and right; the DOOR on the right side of your car is installed upside-down, as Geoffrey mentioned above.
            • Twan B.
              • June 30, 2005
              • 207
              Here the photo's. Hope it works
              • Twan B.
                • June 30, 2005
                • 207
                Did'nt work.
                Put it on my homepage:
                Thanks for looking,
                Twan
                • Harry Sadlock
                  Twan, I looked at the photo and started scratching my head till it hurt. On doors that I am familiar with, the arm on the door that holds the wire is physically different. Also the arm that hold the wire is on the left side of the door. Being on the left side, you would pull the knob under the dash to open the door and push it to close the door. Either someone repaired the door incorrectly or built their own????
                  Can you take the one from the left side and compare it to the right side and see if there is a difference.
                  Harry
                  • Harry Sadlock
                    Are you sure it's from or is a 65 Vette?
                    • Geoff C.
                      • May 31, 1979
                      • 1613
                      Uh ohh That an Air Cond 63-67 RH vent door
                      If you don't have AC, you will beed to change that vent door. However, I really don't think that is possible. You may have an ex AC car. It may have been gutted. Post a picture of the passengers side firewall.
                      Geoffrey Coenen
                      PS If you have a well known illustrated catalog, look on page 50 in the upper LH corner. Or see this pdf file.
                      63-67 Air Cond RH vent door
