cilinder heads 3890462 - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
    Hello
    I have 3890462 heads on the original 1960 CS fuelie engine
    (now running with an edelbrock carb and intake and FI distributor (without vac. advance)and running rough at idle)
    my question is are these heads useable with the original fuelie unit
    because it seems they are not for a 283 engine ???
    thanks in advance Sander,
    Fuelie
    Re: cilinder heads 3890462
    Sander-----
    They're very, very usable with the original fuel injection unit. The combustion chamber is slightly larger than the original heads, so it will slightly drop the compression ratio----less than 1/2 point, I'd say. Otherwise, these heads should work perfectly with FI.
