C1 Window Regulator - NCRS Discussion Boards
C1 Window Regulator
  • Richard H.
    • March 1, 1985
    • 241
    C1 Window Regulator
    Do the 58, 59, and 60 Vettes all use the same window regulator or does the 58 require a different design? Thanks. Richard
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 Window Regulator
    Yep, they are all the same!
    • Geoff C.
      • May 31, 1979
      • 1613
      Disagree
      Old Part books show
      Manual Regulator
      56-58 LH exc PW
      56-58 RH exc PW
      59-62 LH exc PW
      59-62 RH exc PW
      with PW it is a little different
      the part book shows
      PW Regulator only
      56-62 LH w/PW
      56-62 RH w/PW
      AIM shows PW motor & regulator assy
      56-57 LH w/PW
      56-57 RH w/PW
      58-60 LH w/PW
      58-60 RH w/PW
      61-62 LH w/PW
      61-62 RH w/PW
      PW motors probably accounted for difference of 3 different PW varieties
      Geoffrey Coenen
      • Paul M.
        • November 1, 1987
        • 142
        John, I disagree with you. 56 thru 58 are the same and 59 thru 62 are the same. The difference is that the later have a sharper bend on the long arm.
        Paul
        • John M.
          • January 1, 1999
          • 1553
          Re: Disagree
          Geoff,
          You are correct. I was using a power regulator as a point of reference, and can not see any differences, so I just presumed that the manual regulators were the same. That however, brings up a good question, If all the regulators mount at the same place and all window cranks are at the same place, and power regulators are the same, then why wouldn't a later model manual regulator be a functional replacement? Maybe some one who has a deeper knowledge of the differences can explain what changes were made and why. As far as I am aware, the only real obvoius physical difference on 58 doors is the mounting of the inside door release is at a different location.
          Regards, John McGraw
          • John M.
            • January 1, 1999
            • 1553
            (Message Deleted by Poster)
            • Geoff C.
              • May 31, 1979
              • 1613
              Agree. Functionally I believe they are
              interchangeable with little harm or benefit. Geoffrey
              • Mike E.
                • February 28, 1975
                • 5134
                Agree with Paul--the sharper bend is at a slightly different spot in the arm than the other unit. They will functionally interchange. The 56-58 was mounted in a slightly different spot on the door than the 59-62, so they used the same regulator, but bent the arm more, and in a different spot, to get the angle more correct for the 59-62 change. They WILL interchange, but window function may not be quite as smooth with the "wrong" regulator.
