Can you get 3.08 gears to work in a 60 pumpkin w/posi? If so, where can one be obtained?
C-1 pumpkin question
Re: C-1 pumpkin question
Bob,
I installed a 3.08 in my original 57 posi pumpkin.
I believe you can buy new 3.08 gears from Richmond Gear
Good luck,
Verle- Top
I did it in my 57, too.
I bought a 60 pumpkin/posi unit with 3:70 gears and replaced them with a 3:08 gear set and diff rebuild kit from Bob's Rear Ends in CA when I also installed a Richmond 5-speed in my 57. (I can look up the info if you want.) Doing so lost about 800 rpm in 5th gear and helps me get 20+ mpg on the highway again. Over 15000 miles later I've had no problems at all.- Top
I used a pumpkin out a 64 Chevy Passenger Car with 3.08s in my 57. Mine is a 4 speed car and they are nice on the highway.
Bob
- Top
