The oil drain plug on my '66 300 hp smallblock has always been a slow leaker. While changing the oil over the weekend, I sensed it was getting dangerously close to becoming stripped. I tightened it as much as I thought was prudent and it seemed to hold oil upon initial inspection. I drove it the next day (it was 73 in Omaha!) and all seemed fine. However, last night I noticed a fairly large puddle of oil under the car. Its probably only a tablespoon or so, but its definitely leaking more than it did before, and is a problem.
I've read in the archieves that the way to fix this is to drop the pan and replace the "nut plate" into which the drain plug fits. Sounds like the way to go, but I'm not sure were to get the right part. Is this something I can get at the local Chevy dealer? I assume I will no longer be able to use the original drain plug. Is that correct?
Any words of wisdom are appreciated.
