I've determined/believe the front brake drums are the original (correct casting number). They are worn out and will be replaced. One has a spring and one does not. I have seen many springs on front drums, some appear to have each coil to be round all the way round and some appear to have a flat appearance on the side that faces out.
My spring, and I have no idea if it's the original, is round all the way around. Question, what is correct for a 63 drum spring?
Thank You
Harry
Thank You
Harry
