68 435hp expansion tank - NCRS Discussion Boards
  • Houston U.
    • June 30, 2000
    • 75
    Did the 68 435hp, 4-spd, no a/c come with the expansion tank? Should there be a bracket on the right inner fender from factory even if it didn't? What brackets should be on that fender? Thanks...
  • Warren F.
    • December 1, 1987
    • 1516
    Re: 68 435hp expansion tank
    Don:
    My GM parts book lists only for 1968 327 cid (exc. CAC, THM). There is no mention of a 427 cid using a supply tank for this year, that I interpret.
      Don-----
      The only 1968 big block that used a radiator supply tank was the L-88. NO other 1968 big block used a supply tank.
      For 1969 things changed dramatically. ALL 1969 big blocks used a radiator supply tank.
