Aluminum Radiator?
  • John Bauer
    #1
    Aluminum Radiator?
    aluminum radiator john bauer i have purchased an original roadster with an l spd no a c it has a harrison aluminum radiator h steel fan shroud and expansion tank h my question is i thought only lt and ls motors used the aluminum radiator is this correct for my car vette vues shows lt cars with copper radiators the trim tag build date is a vin s very early ' car thanks
  • Roberto L.
    • January 1, 1998
    • 523
    Re: Aluminum Radiator?
    re aluminum radiator roberto luis base engines with manual trans had al radiator expansion tank as you described and metal shroud my base engine has al radiator tank and shroud as you described the other vettes with al rad are zr and zr hope this helps a little best from argentina roberto ncrs
    Roberto J Luis
    RMC
    1970 Corvette Stingray coupe MT 300 HP
    • Bob Patton
      Suggestion: Join NCRS.....
      suggestion join ncrs bob patton i have purchased an original roadster with an l spd no a c greetings john if you aren't a member of ncrs you need to join asap membership is per year imo its the best bang for the buck in the hobby you will get to know great people suberb knowledge just check the recent and past issues of the restorer etc then purchase a judging guide and all the answers will be there bob
      • John Bauer
        Re: Suggestion: Join NCRS.....
        re suggestion join ncrs john bauer thanks i am already a member i will acquire a judging guide
          • 42936
          re aluminum radiator joe lucia an aluminum radiator gm is correct for your car most small blocks with manual transmissions used this radiator from until exceptions were some s with hp small blocks l s ls and all zr and zr used a similar but slightly larger aluminum radiator gm
          • Jerry
            re suggestion join ncrs jerry if everyone were to respond to a question by simply advising each poster to join the n c r s this site would be redundant why not allow the questions and answers speak for themselves this is the most in depth q a site on the net and speaks loudly for the organization
