What do you think?
1963 Engine Casting number
Re: 1963 Engine Casting number
Look at the casting date, if the year is 2 numbers (63) then it is a Tonawanda block-not Corvette. If a single number 3 than it is a Flint Block and indistinguisable from the other more common large number Flint blocks.Bill Clupper #618- Top
Re: Oh no, it is the "original engine"
Does it have the "Flint Plug"?
Attached Files- Top
Re: GM's St. Cathernine, Ontario Foundry
The block was cast in GM St Catherine's, Ontario foundry. These blocks primarily supported Canadian automobile production. Blocks are similar to Tonawanda castings, however, as Mr. Hinckley has pointed out doesn't exhibit the "Flint Plug". Casting numbers are the same except for size, St Catherine characters are much smaller than Tonawanda. Applications may have been Pontiac and Chevrolet products assembled in Canada, Based on all available information, no Corvettes.- Top
flint plug made it easy to convert these blocks
to front feed dry sump oil system. this eliminated several 90 degree turns in the main oil gallery. i would just enlarge the hole to 1/4" NTP. without the flint plug you needed a drilling fixture to get the hole in the correct location. on BBC "tall blocks" for trucks there was a similar drilling used to lube the air compressor for the air brakes BUT what was the orignal use on a SBC?????- Top
Re: flint plug made it easy to convert these block
The only use on a SBC (after '55) was to plug the gun-drilled hole Flint needed to create an internal intersection in the front oil gallery; Tonawanda used a different machining process to create that intersection that didn't require the externally-drilled hole.- Top
