C2 _ under body part need paint ?
  • Steve Daniel (37270)
    • February 1, 2002
    • 377
    In the 63 AIM Sect 1, Sheet A100 item #6 it is called "lock pillar asm to brace-body lock pillar". I call it the body rail that sits on the body mounts which are welded to the frame rail. I have washed the underside and removed surface rust as best I can with a wire brush. Is it recommended to paint this rail? (Body is off) No heavy rust;I would judge it as mild.
    Steve
  • Wayne Womble (5569)
    • May 1, 1982
    • 3605
    Re: C2 _ under body part need paint ?
    I assume you are talking about the side rail of the bird cage? It should be green zinc chromate.
