I have a Federal Mogul "Speed Pro" 30-30 reproduction camshaft installed in my L76 engine. I am trying to determine if, indeed, FM grinds these camshafts exactly the same as GM did.
I understand that the top of the clearance ramp is .017" above the base circle on the original GM cam. This would take up all valve clearance with a .0233" lash setting, based on an actual rocker ratio of 1.37:1.
Are these reliable numbers for the reproduction camshafts, as well? If there is any disparity between the two versions, then I would rather adjust a few thou too loose, than a few thou too tight! Can I safely use the .023" setting with this camshaft. How is this verified?
Joe
Joe
