NOS trim Rings ?? - NCRS Discussion Boards
NOS trim Rings ??
  • Ron Hambrecht
    NOS trim Rings ??
    Anybody know if these are correct and NOS trim rings for a 67 ??
    I thought NOS trim rings had the dual bite teeth ?
  • Kent K.
    • December 1, 1982
    • 1139
    Re: NOS trim Rings ??
    Ron----
    No they are not correct as original. Original trim rings had only 4 "grippers". Someone else will have to fill in their relationship to the valve stem.
    Kent #6201
    Kent
    NCM Founder - Member #718
      Ron-----
      These are GM SERVICE-only trim rings for the 67 Corvette with rally wheel application. The original rings were GM #3901708. These were discontinued in May, 1975 and replaced by the 9796696. Originally, the GM #9796696 were used for some Buick and Pontiac applications.
      • Stephen L.
        • May 31, 1984
        • 3148
        67 NOS trim rings have 4 clips around the edge on a separate metal ring that is clamped in the stainless beauty ring. One of the clips will be positioned at the valve stem hole. Early service replacements also have the 4 clip configuration but they are NOT positioned at the valve stem hole.
