How to fix a loose outside mirror on a 72
Tags: None
- Top
Re: How to fix a loose outside mirror on a 72
Don't have any good ideas about how to hold the nut. It is supposed to be spotwelded to a reinforcement plate. You can remove the screw by drilling out. Purchase a mirror installation kit, which consists of two well-nuts and two screws. You can use this to reinstall your mirror.Dick Whittington- Top
Matt-----
1) Obtain a 8-24 thread size "thread sert";
2) Drill out the stripped hole using a drill the size specified with the "thread sert";
3) Install "thread sert";
4) done.In Appreciation of John Hinckley- Top
