C1 Heater delete brass plugs - NCRS Discussion Boards
  • Ron R.
    • August 31, 1993
    • 159
    Have a quick question about heater delete plugs.
    1. I found at my local hardware store brass block plugs for the
    water pump and engine block. I read that the intake manifold plug should be
    painted silver. I assume the engine block plug is engine orange. Correct?
    2. Do correct plugs have a stamping? Mine has the size in inches stamped
    (1/2, 3/8). Are they stamped or not stamped? If not stamped, I'll have to
    fill mine in before painting.
    Ron
  • mike mccagh
    Re: C1 Heater delete brass plugs
    my 57 heater delete vette's plugs were not embossed with the pipe size. mike
    • Clem Z.
      • January 1, 2006
      • 9427
      that is cheatin!! *NM*
      • Ron R.
        • August 31, 1993
        • 159
        Where does one find the correct plugs?
        Every vendor I call tells me to get them at the hardware store.
