If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I am replacing the wire mold (shield)clips that are located to the exterior side of the driver and passenger seat. When I ordered the new clips they provided 14 clips. Did every rivet require a clip?
Did you get 14 clips or 14 rivets? I believe if memory serves there are only 3 clips per side. I received a similiar amount of pop rivets... probably a mistake in packaging... from Long Island Supply. The pop rivets are incorrect for that application but must be used if the body is on the frame with no access from under the cage
In my 67 there were about 3 clips per side that hold the metal cover/retainer in place. Maybe your 63 is different. Check you AIM for the correct count and location.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
