1958 trunk spear - NCRS Discussion Boards
1958 trunk spear
  • John S.
    • July 31, 1990
    • 292
    1958 trunk spear
    I have a broken driver side 1958 trunk spear. The piece that is missing and I do not have is 5 in. from the bottom. Does any one have any suggestions on how to fix this? If I could find a piece off of another trunk spear could that be grafted on to mine? Thanks for any help. john
    Re: 1958 trunk spear
    Trying to repair your original trunk spear by 'grafting' on the missing portion from a donor spear is a MAJOR undertaking... You're working with rather soft pot metal that's chromed over and getting a solid adhesion at the repair joint is nearly impossible.
    Even if you could pull this off, you'd still be into having the part de-chromed and re-chromed. This won't be cheap as those who will chrome plate pot metal pieces are reasonable scarce animals.
    I think you're into biting the bullet and buying a reproduction spear to replace your original OR shopping hard for decent used original....
