I have a '72 BB. From my understanding all BB came with A.I.R. I have two correct casting numbered exhaust manifolds, dated '70--date codes not judged on manifolds. Now the Rt exaust manifolt has the correct casting number but is a GM1T not a GM2T. I believe the 1 is without AIR and the 2 is with AIR. I am trying to get a correct GM2T with correct casting numbers.
Now for the question, on the right, did this manifold come in a GM2T version or not? From reading a thread titled C3--Big Block exhaust manifold, Joe Lucia on oct. 30 posted that the left had two part number one for AIR one without and the Rt was just 3888028. If the Rt side numbers did not change is it advisable or not to drill the AIR holes into the manifold I have now? I don't know if this is possible or if it would be obvious that I did it instead of the factory.
I made a number of statements that if they are wrong please correct me.
Thank you,
Brandon
Thank you,
Brandon
