(C3 70)correct intake gasket p/n - NCRS Discussion Boards
  • Travis Williamson
    Can someone tell me what the correct intake gasket paragon p/n is for a 1970 L-46 SB motor?
    Is it the 930K (with the tab) or the 2335K (I believe it does not have the tab). The info is located on Page 15 of the C3 catalog I downloaded from paragon.
    http://www.corvette-paragon.com/memb...ads/v30-c3.pdf (20 MB download)
    I just looked in the NCRS tech manual and it says the small block motors should have the tab (my old gasket had a tab), but the tech at paragon said his notes says it shouldnt have the tab. Im not saying he is wrong, I just want to make sure I get the correct gasket. The first time out of lack of experience I used the fel-pro and of course it doesnt fit the contour of the intake so it wont hold the paint.
    thanks
    Re: (C3 70)correct intake gasket p/n
    Travis-----
    1969 had the "tab" on the intake gasket. I believe that Paragon gasket kits 930K and 2335K are the same except for the end seals. The pre-69 end seals used flap-type retainers for the rubber end seals. 1969 and later used "pin" type extensions on the end seals for retention. Otherwise, the side gaskets are the same or, essentially, the same.
    The 2335K is NOT pictured. What is pictured is the 2336K. This is the 73+ gasket which is of a different configuration and without "tab".
    • Travis Williamson
      Thanks Joe! *NM*
