C2 Side Pipe Exhaust - NCRS Discussion Boards
  • Dave Henshaw
  • Barbara S.
    • April 30, 1981
    • 599
    Re: C2 Side Pipe Exhaust
    Dave. Welcome to the board! It's good to see you on here.
    Tony
    • Stephen L.
      • May 31, 1984
      • 3148
      I am curious as to what item 3 is? Riveted bracket......
      I have a side pipe car and don't recall any bracket.
      • Bill Stephenson
        --------Agree with Steve on the riveted bracket.
        --------Also, as with so many parts of these old cars, you just have to see a real one to get an idea what you are looking at. For instance, the rear cut, while perfectly circular was anything but smooth. That cut is always sort of ragged and a few glass hairs almost always stick out. I have seen so called experts sand the edge down and smooth it out but, obviously thats not the way the assembly worker did the job.
        --------And rarely are two front cuts exactly the same. I have seen a bunch of the tab sticking down below the rocker trim on many original side-pipe cars. And, infrequently you will see the cut at a very discernable angle.
        --------Alot of being able to spot pipes that have been added is just having seen others, especially untouched others. All this description stuff is definetly helpful, but in the end go to the meets and the cruises whenever you can. Hope this helps...........Bill S
        • Dave Henshaw
          Thank you all for your comments. #3 was an error on my part, I was refering to the bracket that is riveted to the side pipe cover. The bracket then bolts to the frame. In regard to the birdcage notches for the U-Nuts, what would be the best way to determine if the notches are factory? Are there certain markings or impressions left on the birdcage when they were notched?
          • Wayne W.
            • April 30, 1982
            • 3605
            The knotches were not ground out, but were punched or nipped out. There is a detectable shear that should be present. It would not be impossible but difficult to duplicate this.
