Help, I went to look at my intake manifold for the date (G 2 6)and noted that the little grounding tab that is riveted on the chrome distributor cover was broken off and laying on the manifold. Are these avaiable and able to be riveted back on or is it a send out job? Thank you in advance. Dale
distributor cover
Re: distributor cover
I have to replace the same tab, but also am having trouble finding the plastic like rivets that hold the plastic shield on the underside of the top shielding.
Mine were brittle and two were broken and missing, so I planned to replace all 4 of them on my 68 SB Top Shield. Any ideas on a source?- Top
Dennis, Long Island Corvette has them for C-2's (they use 2). They dont stock parts for C-3's(you said you needed 4). I dont know if they are the same. Maybe someone will give you an answer. If not maybe another post. Dale- Top
