green zinc chromate primer - NCRS Discussion Boards
  • Barbara S.
    • April 30, 1981
    • 599
    Does anyone know if I can buy green zinc chromate primer in a spray can? Any leads would be appreciated.
    Thanks.
    Tony
  • mike mccagh
    Re: green zinc chromate primer
    try Quanta. they ad in driveline. mike
    • Jim D.
      • 2882
      Try a marine supply store. It is used as a primer for painting outdrives. I bought some locally.
      • Scott Marzahl
        Yep, the local marine supply store like Marine West etc. should have it, Quanta only carries "synthetic" zinc chromate primer now.
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          Please don't breathe ANY of that stuff... *NM*
          • Barbara S.
            • April 30, 1981
            • 599
            Thanks guys! *NM*
            • Rob A.
              • December 1, 1991
              • 2126
              Tony,
              Try an aircraft supply store. Sporty's Pilot Shop used to carry it.. it's the real thing and matches the original used on the birdcage frame.
              • Bob B.
                • August 31, 1992
                • 90
                Tony
                If you can not find it locally let me know.
                Bob
                • Bob B.
                  • August 31, 1992
                  • 90
                  WARNING: POSSIBLE LINK BETWEEN CHROMATE PIGMENTS AND LUNG CANCER
                  Several independent technical studies have suggested that excessive inhalation of zinc chromate dust may cause lung cancer. On the basis of these findings, the manufacturers have requested that the sale of zinc chromate primer and zinc chromate primer aerosol be restricted to commercial or professional shop use.
                  • Joel M.
                    • May 31, 1975
                    • 141
                    Re: Thanks guys!
                    Typically marketed as marine outdrive paint. Manufactured by Tempo. 7/10 bucks a can in case lot otys.
                    • Barbara S.
                      • April 30, 1981
                      • 599
                      Lung cancer?
                      well that really chaps my hide.
                      • Joe M.
                        • February 1, 2005
                        • 589
                        Mar-Hyde has a good green chromate primer. Had problems with Eastwoods. I make up my own aluminum arrows for bowhunting and like dull colors for the feather section of the arrows. Preparing the arrows the same way, Eastwoods paint chips off, lost feathers, Mar Hyde takes a beating and stays on. Compatible with the strong glue used to attach feathers.
                        Dupont has a green etching primer compatible with their paints. Used this along with Imron for frames and parts. Holds up quite good.
                        • Dennis D.
                          • March 1, 2000
                          • 1071
                          • mike cobine
                            You find that on almost all paint these days. My lacquer and primer were covered with those warnings. The two-part primer was covered with nothing but warnings. I had to call the company to get mixing instructions.
