66 installing power brakes, help - NCRS Discussion Boards
  • Bill Farmer
    Help. I decided to put power brakes on my car. I pulled the booster out of the box to see how it would line up...it doesn't. I see mounting plate w/weld nuts in the Zip catalog. Do the upper bolts screw into that? If anyone has done this before, please, throw me a bone. Thanks Bill#44207
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 66 installing power brakes, help
    There is an extra mounting plate installed on PB cars, Not with a well nut though.
    • Rob A.
      • December 1, 1991
      • 2126
      Bill,
      You're right about the mounting plate with the weld nuts. The plate gets rivetted to the firewall and accepts the bolts, as you say. If you have an assembly manual, it will give you the measurements for locating the holes in the firewall. If you don't have one, maybe I, or someone can email you a picture of that page in the manual.
      • Rob A.
        • December 1, 1991
        • 2126
        You need four holes, two for the rivets and two for the bolts to go through into the plate.
          The plate, bolts, rivets, and dimensions for the holes are shown in your assembly manual in Section J50, sheet A2.
          • Bill Stephenson
            Bill,
            -----Got a correct master cylinder??? I have a couple of nice caps for same if you need them..........Bill S
            • Bill Stephenson
              -----Oh,,,,Bill, Did you get the tracing and did it help???.........Bill S
              • terry speth
                I would like to upgrade my 67 vette to power brakes. Does anyone sell this plate or do you need to make it. Also do I need to change the brake pedal Terry
                • Rob A.
                  • December 1, 1991
                  • 2126
                  I believe Long Island has the plate in their catalog.
