I'm having a problem with some vacuum actuator valves for the headlamp doors and also the wiper door. They are not allowing the system to hold a vacuum after the car is shut off. The rest of the system is completely tight. I thought I had a few old valves that were inop., but I have found a few new NOS valves and they are exibiting the same problem. Now my thinking is that the rubber plunger seal must be dry from age and is not sealing against the inner wall of the valve. I'm thinking of soaking the bottom of the valves in some oil to possibly bring the seal back some life (if possible). Any suggestions on what type of oil should be used, something that will now swell the rubber too much. Possibly a mineral oil or vegetable oil without a petroleum base, should that be enough to soak into the seals and give them back some life? Any other suggestions? Thanks.
suggestions for vacuum actuator valves / C3
1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
1969 L71 LeMans Blue, Bright Blue Convertible
1970 L46 Monza Red, Light Saddle Convertible - Duntov
1976 L82 Classic White, Firethorn
2013 LS7 Black, Ebony, Convertible
Moved on -
2006 LS2 Black, Ebony, ConvertibleTags: None- Top
Re: suggestions for vacuum actuator valves / C3
Zachary
The new replacements not GM I have bought do not leak but they are a little different than original but would pass a PV. I could see no way to repair them and they are what I found leaking on all my restorations. I read on Corvette Forum that some one their can fix them. You could try a post their.
LyleLyle
