Is anyone familiar with a the above carbon cleaner product that I believe is still available from GM? I undertstand in the "60's is was sold in quart cans by Delco under the name, XX66 Carbon X. Does it work and how does one use it?
GM Top Engine Cleaner
Re: GM Top Engine Cleaner
John-----
I'm very familiar with it. I always found that it worked very well. I prefer the spray can version as clem described. Also, as clem mentioned the directions for use are on the container and vary by which type you use.
The product contains a chemical called "butyl cellosolve" as its main, active ingredient. It will help remove intake manifold, cylinder head, and combustion chamber deposits. I consider it the most effective product on the market for this purpose. It's also "tried-and-true"; it's been around for, at least, 40 years.
Although it might be just fine, I would not use it for a fuel injected, modern vehicle.In Appreciation of John Hinckley- Top
My friend George Brazil, always added a can to every tune up he did at Galles- Groesbeeck Chevrolet(I bought my new 67 C-2 there). It never showed on the ticket. He called it his insurance for "little old ladies" who putted around.- Top
