Radiator Part No. - NCRS Discussion Boards
Radiator Part No.
  • Bill S.
    • August 31, 1999
    • 104
    Radiator Part No.
    I have a box for a Radiator that has a GM part no. 1#3032149 that should be for a 1978 Corvette L-48 Std. trans. Could someone confirm that, as the no. on the box is hard to read. The radiator has a one + 1/2" bottom diameter, and one + 1/4"
    top diameter. It's a repro brass and copper 2" thick 3 core.
    If it fits the 1978 what other years does it fit?
    Bill
    • 43193
    Re: Radiator Part No.
    Bill-----
    I can find no record, at all, of any SERVICE radiator of GM #3032149. So, you must not be reading the number correctly. The number may be on a metal tag which is attached to one of the radiator's side tanks. So, if you can't read it on the box, maybe you'll be able to find it on the radiator, itself. Also, the radiator may have a tag which has a 2 alpha character code (e.g. "MA") on it. That could be helpful.
