The gauge is pegged all the time. I removed wire at sender still pegged. I removed wire at gauge and still pegged. I removed gauge and on the back are three studs. Sensor,power and the third I assume is ground. I believe the gauge is bad because I have continutiy between the sensor post and the other two post. Does this sound right. Thanks ED
C3/78 Oil pressure gauge pegged
