I am in the process of rebuilding my '57 rear differential and brake system, new axle bearings, etc.
Question #1: I am refinishing the rear brake backing plates. They have a blue paint finish on the inner axle side under the dirt. Is that the correct factory finish? If so, I suppose the fronts should also have the same color?
Question #2: What is the correct color of the differential case (i.e. "pig snout")? I have seen some of them a red rust paint color and some black. What is correct please?
Thanks to all.
David
Thanks to all.
David
