C2 Fuel injection cold enrichment adjustment - NCRS Discussion Boards
  • Floyd #21606
    I have a 65 vette with fuel injection, I want to adjust the cold enrichment (choke). The 65 shop manual says to set to index. What is index? It doesn't say anything about x number of notches to rich or lean.
    Any information is appreciated.
    Floyd
    65 Fuelie
  • Mike McKown
    Adjust as required to keep it running after you
    get it started. I don't think the choke will make it start any faster. Make sure your butterfly shaft is not binding and your fast idle linkage is free.
    • William C.
      • May 31, 1975
      • 6037
      Re: Adjust as required to keep it running after yo
      Index is the position in the center of the rich-lean marks on the edge of the thermostat housing.
      Bill Clupper #618
      • G B.
        • December 1, 1974
        • 1407
        Good luck. I think.
        If any 7380 unit runs properly when cold with an assembly line choke cover set near the GM index mark, then that unit is running far too lean when the engine has warmed up.
        • George J.
          • March 1, 1999
          • 774
          Again, Jerry is right....
          The index mark on the choke cover is useless. Adjust it so that the choke releases when you want it to by trial and error.
          George 31887
          • Floyd #21606
            Jerry,George,Mike & Bill - Thanks for the info
            Thanks Guys, For the information, it is greatly appreciated. I think I can get a handle on it now.
            Floyd
            65 Fuelie
