The parking brake handle for my '66 broke off the shaft and over the weekend I drilled out that part of the bolt which remained in the shaft. I could not tell if a screw of some type or pressed in type of pin held the handle on the shaft. I did notice however, that the openning on the bottom of the handle had threads. Thanks
'66 Parking Brake Handle
Re: '66 Parking Brake Handle
John, I am not sure exactly what info you are looking for, but the handle in my late production '66 is held on with a roll pin. Repro handles may use a screw. If you find an original handle you should be able to braze the hole in the shaft, re-drill to fit a roll pin and be back in business. Good luck, Bill- Top
