Guys, I need some help with my 65 7380 fuel injection. It will start but will only run for a few seconds and shut down like it is running out of fuel. The high pressure pump cable is not broken and the economy and power stops are set to the 65 shop manual factory specs. I have seen a little gas wetting on the fuel meter gasket which is above the float. I checked the float settings and it is at factory spec. I have never ran across this problem before, could the needle and seat be leaking? I appreciate any information on my problem.
Floyd,
65 Fuelie
Floyd,
65 Fuelie
