Joe Lucia - NCRS Discussion Boards
Joe Lucia
  • Joseph T.
    • April 30, 1976
    • 2074
    Joe Lucia
    Can identify block casting # 3933163?
    Thanks ...Joe T
    Re: Joe Lucia
    Joe-----
    I think that you must have read the casting number incorrectly. GM #3933163 is the casting number used for the aluminum, rectangular port intake manifold which was originally used on SHP 1968-69 big blocks. It was not, however, originally used for any Corvette application.
    • Joseph T.
      • April 30, 1976
      • 2074
      Re: Joe Lucia
      Joe..you are right..I should have said intake.
      Included in the Wisc. collection are 2 70 LS6 Chevelles with build sheets..and also an assortment of intake manifolds and additional engines for that matter.
      One is an M40 the other is an M22..both with F41
      Thanks..Joe T
        Re: Joe Lucia
        Joe------
        If the 3933163 manifold is on one of the 70 Chevelles, it's not original to the application. The 3933163 was not used in PRODUCTION after 1969, although it was sold for MANY years in SERVICE.
        • Joseph T.
          • April 30, 1976
          • 2074
          Re: Joe Lucia
          Joe
          Two separate issues. Ten ( 10 ) 3163 intakes available. Two original 70 LS6 Chevelles....I did not check the intakes on the engines in the cars.
          Thanks for being particular.
