C1: Wide wheel question - NCRS Discussion Boards
  • Dave F.
    • June 30, 2004
    • 443
    I have a set of wide wheels, but the spare has something strange on it. There are 3 threaded holes on the outside of the rim about 1/4 wide with some sort of rubber nubs in them.
    Picture attached (I think). The nub I'm talking about is in the lower half of the picture, just a little left of center.
    Is this normal for the spare, or is this something somebody did to it? And if so, why would they do it?
    Thanks.
    -Dave
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Dave, My guess (from some experience)...
    ...would be for the attachment of (Dean) "Moon" (Salt Flat) wheel covers... I'd fill the holes w/JB weld and continue w/my life... PS, I've heard tell these wheels are worth quite a few frogskins...
    • Joseph T.
      • April 30, 1976
      • 2074
      Re: C1: Wide wheel question
      Are the three holes equally spaced around the rim? Maybe the wheel had bonneville type moon discs...at one time.
      • Dave F.
        • June 30, 2004
        • 443
        Yes, the holes are equally spaced, and it sounds like I should have them filled before painting.
        Thanks for the help guys.
        -Dave
        • Mark S.
          • July 31, 1983
          • 655
          Many years ago, I put screws through the rim to secure the tire from spinning on the rim during drag racing. (Another possibility)
          • Joseph T.
            • April 30, 1976
            • 2074
            My 57 had the Salt Flat type Moon discs..and thus the 3 holes drilled into and through the wheels. The tires at that time had tubes. Later when I removed the discs and the tubes. I JB welded the holes as DC suggested. Even then..there was a slow air leak.
            • Mark S.
              • July 31, 1983
              • 655
              Dave:
              Your car would not be a white 60 big brake fuel; would it. If so, I did some research on it yaers ago.
              • Dave F.
                • June 30, 2004
                • 443
                It is white, it is a big brake car, and it is a fuelie, but it's an early '59, not a '60. Darn, that would have been nice to get some more info on it.
                Thanks for the reply.
                -Dave
                • Mark S.
                  • July 31, 1983
                  • 655
                  I may have the year wrong. Is this a fairly recent purchase from Minnesota?
