storage - NCRS Discussion Boards
storage
  • kevin bracken
    storage
    storage kevin bracken hi guys this is a great page need some advice on storage for the car will be park in a unheated garage is it better to fill the gas tank or leave it empty put the car onblock or leave the wheel on any extra advice welcome thank a lot keep up the good work
  • Mark
    Re: storage
    re storage mark kevin everything i've read and practiced lately says to change the oil before and after storage check and top up antifreeze check tire pressure and adjust if necessary no need for blocks for winter storage fill gas tank and put in gas stabilizer disconnect battery car should be clean and covered do not start car each month as some folks do unless you don't mind replacing your exhaust system in the spring
