C1 - NCRS Discussion Boards
C1
  • Thomas C.
    Infrequent User
    • August 31, 2004
    • 9
    C1
    Just purchased a "project 1960" , And I have lots of ????? Does it have a trim or data tag anywhere? I have the vin# it was on the tag on the column.Also came with a mostly complete fuel injection unit in the trunk.How can I tell if it belongs to this car because it is not the original motor???
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: C1
    Tom...
    Solid axles never had a trim/data tag, only the vin tag. the numbers on the fuel injection unit can be matched within six months of your 1960 build date will be a good indication if it belonged to your car. Your vin number can be traced to the build date. This board will help you if you state the numbers.
    • Nicholas L.
      • November 1, 1982
      • 340
      Re: C1
      No trim tags. If it has winshield washers the reservoir should be on passenger side for fuel injected cars. No fuel injected have reservoir on driver side. Other posters, I am sure, will have more information for you. Good luck.
      • mike mccagh
        Re: C1
        nut plate on left inner skirt to mount the fi aircleaner? mike
        • Thomas C.
          Infrequent User
          • August 31, 2004
          • 9
          Re: C1
          Fuel injection ser# 1456 Vin # 00867s102758 Thanks again Tom
          • Joel Falk
            Re: C1
            Tom,
            What model number is the FI unit? It is possible it may not even be off a '60.
            • Mike E.
              • February 28, 1975
              • 5134
              Re: C1
              Tom--
              Unit is likely too late for your car---divide your serial number by 15, add to 1001, and that will give you approximately what you need. That unit fits best on a car around 6500 serial number.
