If Joe Lucia is out there, can you please comment on the following:
I am currently looking at an "original" idle stop solenoid bracket, clamp,
and two studs that the owner claims were used for 1969 BB THM400 Corvettes
( L-88 & ZL-1 ). Part numbers are as follows: 3967426 & 3940917. The owner
claims that these were used in conjunction with a 4296 Holley for the Corvette
applications listed. I'm a real stickler for original components.
My question is rather simple ( I hope ). Are these not the same components
that were used for L/78 & COPO & ZL-1 Camaro's with THM400's? I believe they
are. The owner further claims that these items are rare in that they were used
in conjunction with the 4296 Holley that featured a unique throttle arm. If
they are indeed ZL-1 related components, would they not be correct for a ZL-1
Camaro? A COPO Camaro? An L/78 Camaro? The problem is this. L/78 & COPO
Camaro's used the 4346 Holley. ZL-1's used the 4296 Holley. Are the arms
that different? 69 Corvettes used a throttle cable, didn't they? 69 Camaro's
still used a throttle rod ( less the L-6 and cross-ram setups ). In my quest
to learn about the use of the idle stop solenoid on 69 Camaro's with L/78 and
THM400's, I have come up across some conflicting information. I know that we
are off Corvettes in general, but I think the ZL-1 & L-88 options might be
able to help me out.
If any member has an original 1969 L-88 or one of the two ZL-1's that has a
THM400, could I possibly impose on you and ask for an image or two depicting
the idle stop solenoid, bracket, clamp, throttle arm, etc.? I want to see
exactly how this setup was configured from the factory and more importantly
the relationship between the solenoid plunger and the throttle arm on the
Holley. As some may recall, I recently found a true hens tooth ( an original
CX coded THM400 used in COPO and SHP applications ) and I only need to get the
proper idle stop solenoid setup and I am good to go.
I was hoping you folks could help.
Steve
Steve
