Cut Area In RF Fender Skirt Comparison - NCRS Discussion Boards
  • Michael H.
    • January 29, 2008
    • 7477
    Picture below is looking in at the RF inner fender skirt from the wheel side. A small 3/8" X 1" notch, or cut out section, is visible at the lower corner just rear of the brake line. This seems to be typical of 66 production, at least early cars. The next pic will be a slightly different cut.
  • Michael H.
    • January 29, 2008
    • 7477
    2ND Picture
    This is the same area on Gary Beaupres 66 built near the end of production. Note that the entire corner has been removed. This is not the only 66 with a very similar modification and it appears it may be factory. Another 66 has the same cut fiberglass but the rubber control arm shiels is not trimed to match. Anyone have any info on this?
