c2 ex manifolds - NCRS Discussion Boards
c2 ex manifolds
  • ken 54321
    c2 ex manifolds
    what is the best dressing for freshly bead blasted ex manifolds - small block - what can i do to keep ncrs but prevent rusty look
    thanks & happy holidays
    ken magrene #44841
    Re: c2 ex manifolds
    Many prior posts on this issue in the archives... Basically, you'll find several recommendations for different cast iron 'appearing' coating systems with different folks liking this one/that one. Bottom line, IF judges detect you've applied a foreign coating to a part that originally as-cast 'natural' expect to lose 20% of the originality points on that item.
    Most judges are pretty good at spotting artificially coated exhaust manifolds and keep in mind, on the judging field, your car will sit side-by-side with others of the same era to accentuate the difference in color/hue... But, folks often opt to give up the judging points willingly for the benefit of long term, rust free, appearance!
