Carburetor Guys - NCRS Discussion Boards
Carburetor Guys
  • lyndon sharpton
    Carburetor Guys
    what carb is this with the #s 7041200 C1 FA is this a carter built carb?
    Re: Carburetor Guys
    lyndon-----
    GM #7041200 was originally used for 1971 big blocks with automatic transmissions installed in passenger cars, Chevelles, and Camaros. It was not used for Corvettes, though. It is possible that it was manufactured by Carter as many Q-Jets were during this period. If it was, however, that fact will be clearly indicated on the side of the float bowl.
    • lyndon sharpton
      Re: Carburetor Guys
      but those numbers can you decode them? thanks as all ways Joe.
        • 11608
        Re: Carburetor Guys
        C1 = March, first week
        FA = broadcast code. We aren't yet sure how this fits in or what they mean. The 704XXXX number is much more "important" in your case.
        Patrick
        • lyndon sharpton
          Re: Carburetor Guys
          so this is a carter built date code?
          • Clem Z.
            • January 1, 2006
            • 9427
            the carter built Q jets that were built for GM OE
            had the GM numbering system BUT the carter built Q jets for aftermarket auto parts used a carter 4 digit type number. the ones built for GM say "rochester quadrajet by carter" on the side.
            • Mark #28455
              I thought the carter carbs had a different #
              I thought the carter carbs used a part number derivative, has anyone else heard that? Like 7029207 becomes 29207?
              Mark
              • Clem Z.
                • January 1, 2006
                • 9427
                Re: I thought the carter carbs had a different #
                all the orignal equiptment carter built Q jet i worked on had the full GM number. the after market replacement ones had a 4 digit number. i only have see 2 or 3 aftermarket ones.
                  • 11608
                  Re: Carburetor Guys
                  Yes.
                    • 15573
                    Re: Carburetor Guys
                    The date code of C1 is an indicator of a Carter built Q-Jet. Carter used a letter for the month and a single digit for the year. Rochester used a Julian date code -- four numbers for the date.
                    • Mark #28455
                      THANKS! *NM*
